查看: 6817|回复: 11
[83/84] Orion TI-84 Plus Hands-on review
发表于 2013-9-9 05:27:12 | 显示全部楼层 |阅读模式
Hi everyone,
We've received our new TI-84 Plus Orion talking calculator. It's coming with OS 2.55/ORk, and one of the first things we tried was to install it on other TI-84 Plus. It works perfectly, even on TI-84 Plus Silver Edition, revealing us a correctly displayed new model name, "Orion TI-84 Plus Silver Edition" instead of "Orion TI-84 Plus", an hypothetic future upgrade.
But of course without the talking module the OS brings nothing more than 2.55MP, and so that's why we're going to test it on a real TI-84 Plus Orion for you.
Table of contents
  • Introduction
  • Unpacking
  • Design
  • Features
  • Connectivity
  • Compatibility with peripherals
  • Misc
Introduction
We've already talked about the Orion TI-84+ in several previous news when it's been seen at the 2013 T3 conference and when it got released, but here's an overview :
The TI-84 Plus Orion is actually a standard TI-84 Plus, installed with a modified OS 2.55 MP: In addition to standard functions, it communicates with the module that is physically attached (screwed) to the top of the calculator.
The Orion 84+ is destined to be used by blind or visually impaired people as it opens the doors to graphing calculators: speech synthesis for each key pressed, the ability to "read" what is displayed on the screen, "hearing" the graphs (see below for details), to vibrate in some cases (haptic feedback) ...
We had the chance to get a unit (thank you TI !), and here are some more info now :-)
Unpacking
The calculator comes in its package alongside many accessories / additional content (or at least the one we received, we're not sure if it's a prototype ?) :
  • high quality stereo headphones for private use
  • AC adapter / charger
  • guidebook
  • leaflet showing other enhanced TI products for blind/visually impaired people (notably the Orion TI-36X, which we find very well done)
  • (x*sin(x)) graphic, printed and embossed in Braille
Design
The Orion TI-84 Plus calculator consists of a TI-84 Plus on top of which resides the actual Orion module. A dedicated, longer than usual slidecase (with APH / Orbit Research logos) protects both the calculator and its module, quite useful against unwanted keypresses when moving etc.
The 84 Plus Orion weighs of course a bit heavier than a standard 84
Dimensions : 9.3"x3.5"x1", or 23.62x8.9x2.54 cm.
Features
Here are the main features we've explored so far ::
First, the module annouces (rate/voice changeable), in English of course, the keys you press. But in context, it is not necessarily a simple reading of the current key, it can detect that you are writing a number and will thus read the number itself and not the last digit typed (it also applies to the results of a calculation). If you are in the list editor or the table of a graph, it reads the values ​​according to the coordinates of the current point, etc.. It is also able to read the words that are written or returned by a program. Iit is actually a real text-to-speech ("sonograph technology") that does the job :-)
And the reading speed, or rather we should say the ability to quickly speak the keys pressed is impressive, there is no delay (it would have been annoying...).
We can't forget to talk about graphs ;-) :
When the calculator is in the process of graphing something like a function, the user knows it thanks to the audio feedback based on the ends of the curve (or at least, it's a easily reconizable noise that happens to fit what we was pltting at that time), and when the tracing is completed, the module describes the graph with a sound whose pitch fluctuates according to the variations of the curve (and a particular sound is produced when the x-axis is crossed). It's very well done !
You can see/hear it in the video below.
Let's also note that the module reminds the user that the calculator will turn off soon (APD - automatic power down annoucement)
We almost forgot : the module does also make the whole calculator vibrate, under certain conditions.
We still couldn't explore all the Orion features, but it's currently a very powerful and versatile module :)
The module itself has several keys (sound level, preferences , repeat, "Manual" screen reading, etc.), which make it even more useful.
Connectivity
The mini-USB port on the voice module allows recharging, as well as updating its firmware when connected to a computer. It is apparently not possible to exchange data with other calculators or a computer using this port, suggesting that the module is presenting itself to the calculator as an USB device and does not include an USB hub. To exchange data, you will therefore need to use the 2.5mm mini-jack cable (not provided), or remove the voice module (although this is not supposed to be done), so in both cases, it isn't very convenient...
The micro-USB port on the voice module, not mentioned in the documentation is still a mystery. The computer doesn't detect the module when this port is used. However, the website states it's in order to connect other devices, but with no further details (or maybe it's to connect the Braille printer that's talked about ? ). Anyway, no micro-USB adapter or cable is included.
And as mentioned above, the 3.5mm jack port is used to connect stereo headphones or speakers.
We now propose you to test the compatibility of the TI-84 Plus Orion equipped with its module with some devices or accessories. As implied above, unless you remove the voice module (operation not originally planned as the module is screwed), you can exclude a priori all devices requiring the USB. But we still have some choice .
Let's start for example with the TI-Kickstand :
As you can see, this is a special cover/slidecase designed for the TI-84 Plus case types (which therefore also includes the TI-89 Titanium and TI-83 USB Black Plus.fr 2013), putting them in an inclined position, which is very comfortable. Normally two inclinations are possible thanks to a flap which is housed in one of two parallel slots in the back of the calc. Here, the voice module completely blocks the access to the top slot (because it's used to receive the screws attaching the module), but not the bottom slot, which allows to use the TI-kickstand, but only in its maximum angle position.
As a device which doesn't require the USB and uses the mini-Jack, we've got the TI-Keyboard. Are such key presses going to be handled the same way by the system and announced by the voice module like the calculator keys? Discover it in the video ;)
https://www.youtube.com/watch?feature=player_embedded&v=hVHS62gIW9M
In summary : the keyboard itself works very well through the 2.5mm jack port on the module, which is a good thing, but the module reactions are strange and depend upon what we are doing. The main (maybe unintended) advantage is that the keyboard typed keys aren't annonced, which would have made a great commotion if that was the case. But some texts tend to be read twice (two times in a row) by the module. We're going to report the bug and hope for an update
Misc
- The calculator is on sale for just $599 from its official website: http://shop.aph.org/webapp/wcs/s ... 340-00P_10001_11051
Too bad it's so expensive : ( But hey, for the visually impaired , we guess it's a good investment :-)
- For the ones interested, it's possible to follow the evolution of the module versions :
http://tech.aph.org/Orion%20TI-84%20Plus%20Documents/gc_new.htm
- Full online documentation :
http://tech.aph.org/Orion%20TI-84%20Plus%20Documents/gc_doc.htm
- A small downside that we noticed during my few experiments: it happens, probably very rarely in standard use, though : the module gets "out of sync" and thus the connection with the calculator is lost. It does not crash the calculator nor module, but it will no longer work with the calculator as expected. We simply have to reset it, then (keystroke calculator + restart) to make them function again :) we think some ASM programs can cause this more easily / often than during standard use.
But after all, these programs are not "made ​​for" Orion and the frequency of use of such programs for a typical Orion user is probably zero.
- The calculator has a modified 2.55MP operating system (the changes adding the code dealing with the voice module), dubbed 2.55/ORk as already mentionned in a previous news. We also discover that it's including the old Boot Code 1.02. But nothing unusual a priori , since it's obviously an old hardware revision, P, while 1.03 Boot Code was introduced with hardware revision Q.
Co-writen by Adriweb and Critor
Source:
http://tiplanet.org/forum/viewtopic.php?t=12943&p=147634&lang=en
Note: we know about the Youtube problem but didn't find an easy workaround yet - our apologies to those who can't watch it
发表于 2013-9-10 16:36:58 | 显示全部楼层
That is so cool.Thank you very much.But the price of it is too expensive
发表于 2013-9-13 23:40:36 | 显示全部楼层
May you please upload a detail picture? The photos above are just too small...
Anyway, it looks cool.
 楼主| 发表于 2013-9-15 00:07:36 | 显示全部楼层
You should get bigger photos by just clicking on them :)
 楼主| 发表于 2013-9-20 04:56:13 | 显示全部楼层
See it playing music: ;)
http://www.cncalc.org/forum.php?mod=viewthread&tid=9365
发表于 2013-9-20 11:42:59 | 显示全部楼层
为何如此贵?
发表于 2013-9-20 12:22:11 | 显示全部楼层
ueutyi 发表于 2013-9-20 11:42
为何如此贵?
Translate: why it is so expensive
 楼主| 发表于 2013-9-20 18:23:24 | 显示全部楼层
I don't know :(
 楼主| 发表于 2013-9-25 08:24:37 | 显示全部楼层
The Orion voice module hardware - is it worth the price?
http://tiplanet.org/forum/viewtopic.php?p=148687&lang=en
Content not available in english yet, but you might be interested into having a look at the photos already.
Motherboard connectivity:
Motherboard chips:
Yes... Two ARM processors... Far more powerful than the calculator itself! :P
匿名人士  发表于 2013-9-27 19:25:28
Ugh. I seriously doubt the point of doing this. By putting that much effort into a outmoded 84, the developers could absolutely develop an independent one by utilizing the ARM chips in the module.
 楼主| 发表于 2013-11-23 08:57:49 | 显示全部楼层
Great news - the Orion talking module for the TI-84 Plus includes a total of nine different voices associated with common american first names - in order:
  • Paul (default)
  • Harry
  • Frank
  • Denis
  • Betty
  • Ursula
  • Wendy
  • Rita
  • Kate
This evening, let's discover all these voices one after another...
http://www.youtube.com/watch?v=TSSavoNpfLs&feature=youtu.be
(for those who have a way to access Youtube, of course...)
Source : http://tiplanet.org/forum/viewtopic.php?p=152830&lang=en
 楼主| 发表于 2013-11-24 00:21:25 | 显示全部楼层
Chase Crispin has released a new video clip of his voice-enabled graphing calculator, the TI-84 Plus Orion. This time, he provides information about the 11 special keys onto the module.
Among the video clip's contents are the audio configuration menu, accessible through the 'pref' key. A retranscription of the menu follows:
  1. Graph options
  2.         Navigation tone duration
  3.                 200 milliseconds
  4.                 400 milliseconds (default)
  5.                 600 milliseconds
  6.                 800 milliseconds
  7.                 1 second
  8.         Equation playback duration
  9.                 2 seconds
  10.                 3 seconds
  11.                 4 seconds (default)
  12.                 5 seconds
  13.                 6 seconds
  14.                 8 seconds
  15.                 10 seconds
  16.                 12 seconds
  17.                 14 seconds
  18.                 16 seconds
  19.         Negative value noise
  20.                 Off
  21.                 Level 1
  22.                 Level 2 (default)
  23.                 Level 3
  24.                 Level 4
  25.                 Level 5
  26.         Negative value vibration
  27.                 Enabled (default)
  28.                 Disabled
  29.         Coordinate annoucement
  30.                 Only X
  31.                 Only Y
  32.                 Only numbers
  33.                 X before Y (default)
  34.                 Y before X
  35.         Reset graph settings
  36. Speech options
  37.         Voice
  38.                 Paul's voice (default)
  39.                 Harry's voice
  40.                 Frank's voice
  41.                 Dennis' voice
  42.                 Betty's voice
  43.                 Ursula's voice
  44.                 Wendy's voice
  45.                 Rita's voice
  46.                 Kate's voice
  47.         Pitch
  48.                 1
  49.                 2
  50.                 3 (default)
  51.                 4
  52.                 5
  53.                 6
  54.                 7
  55.                 8
  56.                 9
  57.                 10
  58.         Menu item number announcement
  59.                 off (default)
  60.                 on
  61.         Reset speech settings
  62. Orion help
  63.         Battery status
  64.         Firmware version
  65.         Serial number
  66.         Quiet mode
  67.                 Disabled
  68.                 Enabled (default)
  69. Reset all
  70. Exit
There's a surprise: we're learning about the fact that the module contains voice data for multiple persons. Paul was the default speaker until now in our previous experiments, but there are others, with a gender parity for choosing one's companion, as the module provides:
  • 4 male voices: Paul, Harry, Frank and Denis
  • 5 female voices: Betty, Ersila, Wendy, Rita and Kate
Cats are said to have 9 lives, and the TI-84 Plus Orion voice module has 9 voices ;)
Given that the module already supports multiple voice tones, it should be even easier to add other languages in a future update!
But that requires consumer demand for such a feature... ;)
[youtube]http://www.youtube.com/watch?v=0blJnr0i9pM[/youtube]
(for those who can access Youtube...)
Source : http://tiplanet.org/forum/viewtopic.php?p=152308&lang=en
GMT+8, 2025-1-23 08:05 , Processed in 0.057659 second(s), 21 queries .
