查看: 6717|回复: 2
Put a Samsung Galaxy S3 battery in your HP-Prime
发表于 2013-10-6 06:51:34 | 显示全部楼层 |阅读模式
In a previous news we were presenting you the new HP-Prime and its rechargeable battery providing a voltage of 3.7 Volts like on the TI-Nspire and TI-84 Plus C Silver Edition, but with a much greater capacity of 1500 mAh and thus an increased energy of 5.55 Wh ! {:thumbsup:}
Without any cable unlike on TI models, the HP-Prime rechargeable battery is very easy to install and remove.
According to an information revealed by Tim Wessman from HP on the TI-Planet HP Wiki, the battery coming with the HP-Prime is actually of the same type as those used by the Samsung Galaxy S3 smartphone, which is great a news!{:thumbsup:}
On the one hand, with the existence of generic brands of batteries for this phone, when the time comes you'll be able to buy a HP-Prime replacement battery for cheap!{:thumbsup:}
On the other hand, the most common battery for Samsung Galaxy S3 does provide a compatible voltage of 3.8 Volts, but has a capacity of 2100 mAh and therefore an energy of 7.98 Wh. Thus we can expect from it performances 40% higher than the original HP-Prime battery! The replacement will get you a much better autonomy! {:thumbsup:}
You can even try to opt for more powerful Samsung Galaxy S3 rechargeable batteries, especially in generic brands. Exceeding 2500 mAh, 3000 mAh or even 4000 mAh capacity is possible for an unexpected autonomy! But beware, these batteries are often thicker and thus require some accessories designed for the phone (back cover replacement, special battery cover, battery case extension...). These accessories probably won't be usable with the HP-Prime case. Si if you opt for these powerful batteries, make sure that you buy rechargeable batteries which don't require such accessories.
Source:
http://tiplanet.org/forum/viewto ... =149441&lang=en
发表于 2013-10-6 07:40:12 | 显示全部楼层
The ideal calculator is powered by AA battery with alternative rechargable battery, like Nspire TouchPad.{:014:}
发表于 2013-10-6 21:27:42 | 显示全部楼层
ExAcler 发表于 2013-10-6 21:02
交流电池?
alternating current battery?
GMT+8, 2025-1-22 17:49 , Processed in 0.059744 second(s), 25 queries .
