返回列表 发新帖回复
楼主: 六合江山QQ
[Nspire] Nspire Color EVT到手
 楼主| 发表于 2013-10-11 19:18:37 | 显示全部楼层
critor 发表于 2013-10-11 19:14
Thanks. :)
Is it version 3.00.102 too? Version number can be found in "8. Information Screen".
    Test_InformationScreen
NSC EVT Version3 Diag Menu
DATE:2010-9-24    18:7:43
3.00.102
ESC to EXIT
发表于 2013-10-11 19:20:30 | 显示全部楼层
Thank you very much :)
For information, it's a picture publicly available on the Internet, from the Aspen (Colorado) hot air balloon festival.
Source: http://tiplanet.org/forum/viewtopic.php?t=10992&p=133925
发表于 2013-10-12 00:15:13 | 显示全部楼层
六合江山QQ 发表于 2013-10-11 15:29
New prototype found on Taobao.
http://item.taobao.com/item.htm?spm=a230r.1.14.62.ByQ8Ke&id=183590 ...
It would be nice to get it and check those cut cables connections.
I wonder if they have the same purpose as the cut cables found on the TI-Nspire CM prototype from zweb:
 楼主| 发表于 2013-10-12 01:21:08 | 显示全部楼层
For information, it's a picture publicly available on the Internet, from t ...
One thing weird,My Color EVT has its screen flicking.
And it is much faster to do sumation,eg. sum(sin(x),1,10000) than a production CX CAS.
Nevertheless the power comsumption of that EVT is unbeliveable.
A battery could be used up in one day(play some Ti-basc program), even though I have interchanged its battery with my CX CAS(which battery is still full at the end of day).
I suspect The Color EVT has been overclocked, or exist some hardware defect.
Could you leave me some benchmark program which can be use to test its performance?
发表于 2013-10-12 23:00:20 | 显示全部楼层
We just got a TI-Nspire CX with the J04/JTAG connector - thank you very much!{:thumbsup:}
Source with bigger pictures:
http://tiplanet.org/forum/viewto ... mp;p=150003#p150003
 楼主| 发表于 2013-10-12 23:24:52 | 显示全部楼层
This one is much close to production model.
There is labeled a 2nd function undo above esc key , which is blank on NS color and CX CAS prototype.
Anyway, the prototype can also perform undo.
发表于 2013-10-15 14:04:39 | 显示全部楼层
critor 发表于 2013-10-10 22:12
Hi!
Nice find - thank you for the pictures and the dump.
I would like to ask two question: Is it possible to launch development OS on a production model?And how to find syscall address?nLaunch used some boot2 syscalls , I want to know the address of them on CM
发表于 2013-10-16 00:01:12 | 显示全部楼层
It should be possible after modifying Nlaunch, yes.
GMT+8, 2025-1-23 07:04 , Processed in 0.056677 second(s), 19 queries .
