楼主: wtof1996
[Nspire] [更新:加入对完整版本3.6的支持]Ndless 3.6 Switching Pack (附中文教程)
发表于 2013-10-17 21:22:50 | 显示全部楼层
没有那个休眠的问题吧?我已经刷上了
发表于 2013-10-19 17:57:07 | 显示全部楼层
期待有中文语言的OS3.6/3.1
发表于 2013-10-20 16:32:40 | 显示全部楼层
我按照nLaunch的说明(http://www.cncalc.org/forum.php? ... &fromuid=107261)去除了TI-NspireCXCAS-3.6.0.546.tcc中的boot2,但是无法用nLaunch轮换,尝试失败。
发表于 2013-10-22 20:47:52 | 显示全部楼层
The Ndless 3.6 switching pack has now been updated with support for the non-CAS TI-Nspire CX:
http://tiplanet.org/forum/viewtopic.php?f=43&t=13260
发表于 2013-10-23 07:10:14 | 显示全部楼层
http: ...
那个for CAS的switch木有中文支持啊,制作的原理是什么呢,如果有DIY方法,就自己弄一个
 楼主| 发表于 2013-10-23 14:35:36 | 显示全部楼层
keypress 发表于 2013-10-20 16:32
我按照nLaunch的说明(http://www.cncalc.org/forum.php?mod=redirect&goto=findpost&ptid=9279&pid=123459 ...
3.6原版用TNOC干掉BOOT2会挂,这里的是第三方的泄露特制版本,我们也不知道如何制作
 楼主| 发表于 2013-10-23 14:54:36 | 显示全部楼层
http: ...
Thanks, but in this package I couldn't find "/nlaunch/phoenix.old.tns"(the phoenix.tns is OS3.6) .So I think maybe you should modify the instruction?
发表于 2013-10-23 21:12:54 | 显示全部楼层
The phoenix.old.tns files links are in the readme.
Download them separately, add them to the pack in the 'nlaunch' folders and it's complete.
发表于 2013-10-30 19:30:40 | 显示全部楼层
Ndless/3.6 switching pack has now been updated again, with the new nLaunch.
The new pack does now include all required files and doesn't need a modified OS 3.6 image anymore.
It now supports all TI-Nspire models:
- TI-Nspire
- TI-Nspire CAS
- TI-Nspire CX
- TI-Nspire CX CAS
Download:
http://tiplanet.org/forum/archives_voir.php?id=21229
Installation how-to in english:
http://tiplanet.org/forum/viewto ... t=13213&lang=en
参与人数 1金钱 +3 收起 理由
Ulysses + 3 Good job !
 楼主| 发表于 2013-10-30 21:56:46 来自手机 | 显示全部楼层
The new pack does now ...
Thank you very much, I will update this translation as quick as possible.
BTW,does this version mean we could use a normal OS3.6 which includes fully support on Chinese Language?
发表于 2013-10-30 23:20:15 | 显示全部楼层
Yes, it's designed for the original OS 3.6 with chinese language support. :)
发表于 2013-11-4 10:39:37 | 显示全部楼层
占位围观窝头好贴{:015:}
发表于 2013-11-4 13:48:18 | 显示全部楼层
成功了23333333333333333333333333333333
发表于 2013-11-30 13:54:47 来自手机 | 显示全部楼层
表示开头没有看懂,我现在是cx-c nlaunch3.1和3.2,是只要导入新的nlaunch后加上新的3.6版的os backup就可以了吗,3.6的os又应该是哪一个?
 楼主| 发表于 2013-11-30 14:42:29 | 显示全部楼层
mlc97 发表于 2013-11-30 13:54
表示开头没有看懂,我现在是cx-c nlaunch3.1和3.2,是只要导入新的nlaunch后加上新的3.6版的os backup就可以 ...
建议卸载以后重装,开头部分指的是早先的不支持中文的3.6 switching pack
发表于 2013-11-30 18:26:30 | 显示全部楼层
谢谢
发表于 2013-12-25 20:24:57 | 显示全部楼层
为什么尾号j不可以。。。。。。
 楼主| 发表于 2013-12-25 21:36:43 | 显示全部楼层
cnjzxy 发表于 2013-12-25 20:24
为什么尾号j不可以。。。。。。
新版做了封杀
发表于 2014-1-14 14:03:27 | 显示全部楼层
感谢分享~{:014:}
发表于 2014-1-14 14:27:50 | 显示全部楼层
安装时显示pp123和pp1234是对的吗?
GMT+8, 2025-1-22 23:45 , Processed in 0.085588 second(s), 22 queries .
