查看: 3723|回复: 6
[Nspire] nspire non-cas用nlaunch安装3.6后卡在启动的麻点屏幕,中间的转圈根本不动后死机
发表于 2013-11-9 17:24:38 | 显示全部楼层 |阅读模式
nspire non-cas用nlaunch安装切换包的3.6后卡在启动的麻点屏幕,中间的转圈根本不动后死机
然后就是发现系统最低限制限定在3.6了,装删除boot2 的3.2也会提示系统太低....
那么只能用nlaunch启动更低系统了?也就是我这台其实是披着量产外衣的工程机?
啊啊啊啊
@六合江山QQ
发表于 2013-11-9 17:37:30 | 显示全部楼层
use nlaunch toggle to 3.1,拿nsNandMgr remove limitation。
If you cannot do that,@critor
 楼主| 发表于 2013-11-9 17:58:49 | 显示全部楼层
ok,got it !
 楼主| 发表于 2013-11-9 17:59:11 | 显示全部楼层
i'll try this
发表于 2013-11-9 19:43:04 | 显示全部楼层
Yes, OS 3.6 even used with Nlaunch still sets the minimal installable OS version to 3.6.
Reinstall Nlaunch to launch OS 3.1.
You can then use nsNandMgr to remove the minimal installable OS version.
发表于 2013-11-9 19:51:17 | 显示全部楼层
 楼主| 发表于 2013-11-9 20:13:52 | 显示全部楼层
Reinstal ...
ok.thank you!
GMT+8, 2025-1-23 08:00 , Processed in 0.051157 second(s), 18 queries .
