查看: 6904|回复: 5
[Nspire] New TI-Nspire 3.6.0.550 OS & softwares
发表于 2014-2-6 18:07:23 | 显示全部楼层 |阅读模式
After uploading the TI-Nspire 3.6.0.546 versions last october, Texas Instruments has just released a new update, 3.6.0.550.
This update affects the international TI-Nspire range :
  • OS for TI-Nspire, TI-Nspire CAS, TI-Nspire CX and TI-Nspire CX CAS
  • TI-Nspire Student Computer software for PC/Windows and Mac
  • TI-Nspire Computer Link software for PC/Windows and Mac
Note that like last times, the chinese TI-Nspire CM models are not concerned and therefore remain stuck to version 3.2.0.1219.
However, the version number suggests only 4 rebuilds of the system since the last release, and it would therefore a priori seems something minor.
  • The analysis of the OS indicates a compilation on January 14th, 2014.
  • The minimum installable OS version remains unchanged at 3.6.0.546, and so this new OS 3.6.0.550 does not prevent you from reinstalling the previous 3.6.0.546 version.
  • The Boot2 versions included in the OS files have not changed and are therefore 3.2.4.7 for TI-Nspire CX and 3.0.1 for TI- Nspire ClickPad/TouchPad.
Links :
Source : https://tiplanet.org/forum/viewtopic.php?p=157166
发表于 2014-2-6 19:15:38 来自手机 | 显示全部楼层
I wonder if there will be a modified version for nluanch?
发表于 2014-2-6 20:03:13 来自手机 | 显示全部楼层
坐等和谐版
 楼主| 发表于 2014-2-6 20:57:42 | 显示全部楼层
Just added the TI-Nspire Teacher software links.
Teacher software will be usable without a licence for a 90-days instead of 30. ;)
发表于 2014-2-6 21:34:35 | 显示全部楼层
Cool!But if my TI-Nspire CAS has updated to 3.6,should I update to this version?(Although I still use 3.2{:tongue:})
I'm sorry about my English......
 楼主| 发表于 2014-2-7 05:32:38 | 显示全部楼层
No problem with your english :)
Nothing new as far as I know.
GMT+8, 2025-1-23 10:44 , Processed in 0.062004 second(s), 21 queries .
