查看: 3292|回复: 2
[Nspire] Nspire linux内核USB驱动 提取自/sys/bus/usb/drivers
发表于 2014-3-15 12:00:18 | 显示全部楼层 |阅读模式
提取自/sys/bus/usb/drivers      看起来都是原linux内核中的
由于自己对linux内核也不是特别了解 所以也不知道会不会特别有帮助
下面说几个我认识的 应该对OTG实现上网甚至无线上网有启发
人在学校 最近是没空鼓捣了。。大神们可以用支持的网卡试试
drwxr-xr-x    2 root     root             0 Mar 17 09:44 MOSCHIP usb-ethernet driver          显然是moschip的网卡驱动
drwxr-xr-x    2 root     root             0 Mar 17 09:44 aircable    目测是蓝牙适配器 蓝牙网络也可能可以连接
drwxr-xr-x    2 root     root             0 Mar 17 09:44 appletouch   水果牌触控板
drwxr-xr-x    2 root     root             0 Mar 17 09:44 ark3116  串口
drwxr-xr-x    2 root     root             0 Mar 17 09:44 asix USB网卡
drwxr-xr-x    2 root     root             0 Mar 17 09:44 at76c50x-usb  老式802.11b的网卡
drwxr-xr-x    2 root     root             0 Mar 17 09:44 ath3k
drwxr-xr-x    2 root     root             0 Mar 17 09:44 bcm203x  蓝牙
drwxr-xr-x    2 root     root             0 Mar 17 09:44 bcm5974  这应该是触屏控制驱动啊!
drwxr-xr-x    2 root     root             0 Mar 17 09:44 belkin_sa
drwxr-xr-x    2 root     root             0 Mar 17 09:44 bfusb
drwxr-xr-x    2 root     root             0 Mar 17 09:44 bpa10x
drwxr-xr-x    2 root     root             0 Mar 17 09:44 brcmfmac
drwxr-xr-x    2 root     root             0 Mar 17 09:44 btusb
drwxr-xr-x    2 root     root             0 Mar 17 09:44 cdc_acm
drwxr-xr-x    2 root     root             0 Mar 17 09:44 cdc_eem
drwxr-xr-x    2 root     root             0 Mar 17 09:44 cdc_ether
drwxr-xr-x    2 root     root             0 Mar 17 09:44 cdc_ncm
drwxr-xr-x    2 root     root             0 Mar 17 09:44 cdc_subset
drwxr-xr-x    2 root     root             0 Mar 17 09:44 cdc_wdm
drwxr-xr-x    2 root     root             0 Mar 17 09:44 ch341
drwxr-xr-x    2 root     root             0 Mar 17 09:44 cp210x
drwxr-xr-x    2 root     root             0 Mar 17 09:44 cx82310_eth
drwxr-xr-x    2 root     root             0 Mar 17 09:44 cypress_m8
drwxr-xr-x    2 root     root             0 Mar 17 09:44 digi_acceleport
drwxr-xr-x    2 root     root             0 Mar 17 09:44 dm9601
drwxr-xr-x    2 root     root             0 Mar 17 09:44 empeg
drwxr-xr-x    2 root     root             0 Mar 17 09:44 f81232
drwxr-xr-x    2 root     root             0 Mar 17 09:44 ftdi_sio
drwxr-xr-x    2 root     root             0 Mar 17 09:44 funsoft
drwxr-xr-x    2 root     root             0 Mar 17 09:44 garmin_gps
drwxr-xr-x    2 root     root             0 Mar 17 09:44 gl620a
drwxr-xr-x    2 root     root             0 Mar 17 09:44 hp4x
drwxr-xr-x    2 root     root             0 Mar 17 09:44 hub
drwxr-xr-x    2 root     root             0 Mar 17 09:44 io_edgeport
drwxr-xr-x    2 root     root             0 Mar 17 09:44 io_ti
drwxr-xr-x    2 root     root             0 Mar 17 09:44 ipaq
drwxr-xr-x    2 root     root             0 Mar 17 09:44 ipheth
drwxr-xr-x    2 root     root             0 Mar 17 09:44 ipw
drwxr-xr-x    2 root     root             0 Mar 17 09:44 ir_usb
drwxr-xr-x    2 root     root             0 Mar 17 09:44 iuu_phoenix
drwxr-xr-x    2 root     root             0 Mar 17 09:44 kalmia
drwxr-xr-x    2 root     root             0 Mar 17 09:44 kaweth
drwxr-xr-x    2 root     root             0 Mar 17 09:44 keyspan
drwxr-xr-x    2 root     root             0 Mar 17 09:44 keyspan_pda
drwxr-xr-x    2 root     root             0 Mar 17 09:44 kl5kusb105
drwxr-xr-x    2 root     root             0 Mar 17 09:44 kobil_sct
drwxr-xr-x    2 root     root             0 Mar 17 09:44 lg-vl600
drwxr-xr-x    2 root     root             0 Mar 17 09:44 mct_u232
drwxr-xr-x    2 root     root             0 Mar 17 09:44 metro_usb
drwxr-xr-x    2 root     root             0 Mar 17 09:44 mos7720
drwxr-xr-x    2 root     root             0 Mar 17 09:44 mos7840
drwxr-xr-x    2 root     root             0 Mar 17 09:44 moto_modem
drwxr-xr-x    2 root     root             0 Mar 17 09:44 navman
drwxr-xr-x    2 root     root             0 Mar 17 09:44 net1080
drwxr-xr-x    2 root     root             0 Mar 17 09:44 opticon
drwxr-xr-x    2 root     root             0 Mar 17 09:44 option
drwxr-xr-x    2 root     root             0 Mar 17 09:44 oti6858
drwxr-xr-x    2 root     root             0 Mar 17 09:44 pegasus
drwxr-xr-x    2 root     root             0 Mar 17 09:44 pl2303
drwxr-xr-x    2 root     root             0 Mar 17 09:44 plusb
drwxr-xr-x    2 root     root             0 Mar 17 09:44 qcaux
drwxr-xr-x    2 root     root             0 Mar 17 09:44 qcserial
drwxr-xr-x    2 root     root             0 Mar 17 09:44 qmi_wwan
drwxr-xr-x    2 root     root             0 Mar 17 09:44 quatech2
drwxr-xr-x    2 root     root             0 Mar 17 09:44 rndis_host
drwxr-xr-x    2 root     root             0 Mar 17 09:44 rndis_wlan Broadcom 4320无线网卡
drwxr-xr-x    2 root     root             0 Mar 17 09:44 rt2500usb Ralink无线网卡
drwxr-xr-x    2 root     root             0 Mar 17 09:44 rt2800usb Ralink无线网卡
drwxr-xr-x    2 root     root             0 Mar 17 09:44 rt73usb Ralink无线网卡
drwxr-xr-x    2 root     root             0 Mar 17 09:44 rtl8187 Realtek无线网卡
drwxr-xr-x    2 root     root             0 Mar 17 09:44 rtl8192cu Realtek无线网卡
drwxr-xr-x    2 root     root             0 Mar 17 09:44 siemens_mpi
drwxr-xr-x    2 root     root             0 Mar 17 09:44 sierra
drwxr-xr-x    2 root     root             0 Mar 17 09:44 sierra_net
drwxr-xr-x    2 root     root             0 Mar 17 09:44 spcp8x5
drwxr-xr-x    2 root     root             0 Mar 17 09:44 ssu100
drwxr-xr-x    2 root     root             0 Mar 17 09:44 symbolserial
drwxr-xr-x    2 root     root             0 Mar 17 09:44 synaptics_usb
drwxr-xr-x    2 root     root             0 Mar 17 09:44 ti_usb_3410_5052
drwxr-xr-x    2 root     root             0 Mar 17 09:44 ums-realtek
drwxr-xr-x    2 root     root             0 Mar 17 09:44 usb
drwxr-xr-x    2 root     root             0 Mar 17 09:44 usb-storage u盘
drwxr-xr-x    2 root     root             0 Mar 17 09:44 usb8797
drwxr-xr-x    2 root     root             0 Mar 17 09:44 usbfs
drwxr-xr-x    2 root     root             0 Mar 17 09:44 usbhid
drwxr-xr-x    2 root     root             0 Mar 17 09:44 usbserial
drwxr-xr-x    2 root     root             0 Mar 17 09:44 usbserial_generic
drwxr-xr-x    2 root     root             0 Mar 17 09:44 visor
drwxr-xr-x    2 root     root             0 Mar 17 09:44 vivopay_serial
drwxr-xr-x    2 root     root             0 Mar 17 09:44 whiteheat
drwxr-xr-x    2 root     root             0 Mar 17 09:44 zaurus
drwxr-xr-x    2 root     root             0 Mar 17 09:44 zd1201
drwxr-xr-x    2 root     root             0 Mar 17 09:44 zd1211rw
drwxr-xr-x    2 root     root             0 Mar 17 09:44 zio
drwxr-xr-x    2 root     root             0 Mar 17 09:44 zte_ev
ls -l的原始输出
lsad.txt (6.28 KB, 下载次数: 17)
参与人数 2金钱 +6 收起 理由
Cursor + 3 不明觉厉但是好像牛逼的样子!
HHX-XXM + 3 很给力!
发表于 2014-3-15 12:48:10 来自手机 | 显示全部楼层
不明觉历
发表于 2014-3-15 15:53:23 | 显示全部楼层
不明觉厉
GMT+8, 2025-1-23 10:30 , Processed in 0.081936 second(s), 22 queries .
